Simple MIOS Application
Just upgraded to the MIOS system.
I’m trying to implement basically the MIDIO128 using the MIOS system, which should be fairly easy, but i can’t seem to figure out how to do it.
Basically all i want, is 16 independant DOUT channels, controlled via MIDI controllers on one channel.
and, 8 independant Push buttons, which when pressed send a MIDI controller on another channel.
I know this should be easy to implement, but i can’t seem to separate the buttons, and DOUT channels.
Any suggestions would be most apriciated
Many Thanks
Michael
Many Thanks
Michael
Hi Michael,
you could use the ain64_din128_dout128_v1_1 application as inspiration. It allows to connect up to 128 buttons, 128 LEDs and 64 pots. Just remove the pot handler if you don’t need it. In USER_Init the number of pots have to be set to 0.
The MIDI events for buttons and LEDs are defined in mios_tables.inc
Hi Michael,
