This is based on a previous design I had used in the past with some improvements (smaller size, switching 5V reg). Its a 7VA trafo which gives 580 mA max, not a lot but enough for my needs (size was the big factor here). Standard 7812 and 7912 linear vRegs with a switching Recom R-785.0-0.5 for the +5. Total cost was ~$50 including the board. If anyone is interested, I’ll post the BOM and eagle files
Especially the linear regs are good for AOUT stuff - methinks using switchers (like in those commonly available “open frame psus”) are not top notch for feeding into modular stuff…
Many greets,
Peter
If you want to use a linear regulator for modular stuff, wouldn’t you rather use an LM317/337?
I didnt go with the adjustable for simply for size, no need for it here. I may need to make some 220V versions of this and would be willing to offer 2 boards with the right transformer, switching 5V vReg, and bridge rectifier as a partial kit. If anyone is interested, shoot me a PM
Using a 18-0-18 trafo for a +/- 12 setup is a waste and you’re just burning off that extra voltage as heat. Measure the input of your vRegs, you are probably around 24V!
A transformers VAC output is an RMS measurement so to find out the corresponding DC output (at load) the formula is VP =(V secondary rms x 1.414) - 1.4 V
I have been using Kicad to design boards so i dont have eagle. maybe the gerber files would be usefull. sorry for questioning the design. i was just trying to help. Any chance for an oshpark share. i have some boards up there too.
