Oh, that very much looks cool, SM. I first got into modular-like computer software through Jeskola Buzz. Are you familiar with that program?
Hmm. I’m not making any promises, but when my MBSID is finished perhaps i’ll work on a Reaktor controller for it like yours, and maybe add some ideas of mine. I think it would be good for the scene to see more people taking it upon themselves to add to the available tools instead of just asking for them. Not that there’s anything wrong with that.
it seems to me that it transmit only to channel1 even if you set a different channel. i can solve this problem via software with my creamware audio card, but maybe other cannot
it could be GREAT if the vst could accept incoming CC and update its setting after receivinv a CC: in this
way you can transfer the current patch data from the midibox sid to the VST and edit it on the screen!
anyway, thank you very much for this great device!!
does anyone here use Abelton Live? The vst loads fine for me but it does not seem to send MIDI out? This is related to Live I’m guessing because the VST works great for me in Audiomulch and many other people are having success with Cubase.
Fantastic work SM, really something I could use. Can’t believe I didn’t discover this earlier, but then again, I only ever visit when I have a problem, so it’s my fault. Makes me feel I should contribute to this community more.
I’ve had some annoying issues in using the MbSID in my sequencer, I belive it sends an “all controllers off” at the end of a recording, which seems to mute the MbSID, so I have to change the patch back and forth for every few bars of recording. Now I can avoid this and even automate controls!
but when i load the sid vst control there is not the midi out to connect it to the output of energy xt…
I have just tried out the energy-XT-Demo and I found out that the current versions of SidControl are NOT compatible with this Software. -sorry…
It is not because of the missing midi-out connectors because SidControl HAS NO CONNECTORS. Try the latest demo of ‘Audiomulch’ - a powerful Host for ‘chaining’ VST-Plugins http://audiomulch.com/download.htm , load the SidControl-VST and you’ll see what I mean. After setting up SidControls MIDI-port (only!) You can play the Plugin without any problems.
Be sure that Audiomulch is running - if not press ‘Play’
I think that energy-XT is not made for ‘non-soundprocessing-VST-Synths’ and it eats SidControl’s MIDI-data …
