has anyone wired a pot to the SID audio outs to control volume. If not how have anyone tackled the volume issue. Any ideas? Or will a simple audio taper pot work.
First: There will be an AOUT extension from TK soon, so you can control Pan and Volume of the four SIDs digitally (but the result will be analog!).
Second: The volume can already be changed with the Volume Control by MIDI.
But if you want to change the volume anyhow, a simple pot between 0V and the signal will do the work. (Search for passive mixer schematics on google or somewhere, then you will understand how that functions - fairly easy).
