mat_s
August 24, 2007, 5:43pm
1
i am building a sid v2, with 1 core and 2 sids.
only ! core, so i don’t really need the CAN connection.
so my question is: could i connect the LCD in 8bit (using all the pins on core J15) instead of 4bit, since i don’t need CAN ?
in a previous thread i read about a compile option in mios.h
#if PIC_DERIVATIVE_TYPE == 4
LIST P=PIC18F4685, R=DEC
#include <p18f4685.inc>
#define PIC_DERIVATIVE_CODE_SIZE 0x18000
#define PIC_DERIVATIVE_RAM_SIZE 0xd00
#define PIC_DERIVATIVE_EEPROM_SIZE 0x400
#define PIC_DERIVATIVE_IRQ_WORKAROUND 0
#define PIC_DERIVATIVE_T08BIT_INVERTED 0
#define PIC_DERIVATIVE_SET_LCD_4BIT 1
#endif
i guess i would need to change PIC_DERIVATIVE_SET_LCD_4BIT to 0 ?
any chance that it could work ? or am i having the wrong idea ?
thanks!
(oh, btw i wonder if my lcd is a pled type ? i would say no, but i am not sure. i bought that one:
http://character-lcd-lcds.shopeio.com/inventory/details.asp?id=1143&cat=Lcds&sub=Character%20Lcd )
Wilba
August 24, 2007, 5:54pm
2
The “compile option in mios.h” is for controlling the compilation of MIOS.
It is MIOS which will default to 4-bit mode for LCDs when the PIC is PC18F4685. So it is best to leave it alone and use 4-bit mode and not recompile MIOS.
If at some point you discover that display does not like 4-bit mode (unlikely) then you can use a custom LCD driver to connect it in 8-bit mode. But there’s no need to use 8-bit mode until you have a problem with 4-bit mode.
mat_s
August 24, 2007, 6:16pm
3
ok, i understand now. thanks wilba.
T.K
August 24, 2007, 6:42pm
4
Sidenote: there isn’t really an performance impact when using 4bit mode
mat_s
August 24, 2007, 8:43pm
5
oh, i was not really worried about performance. i was just being a bit lazy and wondered if i could simplify the spaghettis inside the box.
Type: Yellow STN
Not a PLED, just your standard Super-Twisted Nematic LCD.
mat_s
August 30, 2007, 11:15am
7
thanks, you confirm my guess. i think i understood the difference now.
cheers
