Sid sync problems
Im having trouble trying to sync the sid to Cubase sx2. I´ve tried to set the sid to sync the wavetable using both jsynlib, controller 125 on a midikeyboard and controller 125 in Cubase. As far as I know cubase send out the midi clock (the light on the midi output flickers during playback when I set cubase to transmit midiclock.
I´ll be happe for any help… Thanks alot!!
js
js, see http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=troubleshooting;action=display;num=1063305798;start=3#3
short story - enable sync for wavetable in jsynthlib, set tempo for clock divider (try 123), store the patch and you should be good.
hope this helps..
Justin
