Sid step B w 7 add. buttons & leds and 2x40 lc
Last year I godt mid Sid up and running and now id like to extend it with another sid. Also i´d like to make a control panel for it. I like to make a step B version of the control panel with the leds conneted to J5 but with a 2x40 lcd instead og the 2x20 whown on the schematics here: http://www.ucapps.de/midibox_sid_cs/2x20_enc_multi_w_j5.pdf
Is the possible without too much programming-knowledge or sould i buy a 2x20 instead?
Thank you all for any help! :smiley:
js
Not too hard. Just change the following, re-assemble and use convert.bat to create the syx.
Change this in main.asm
#define CS_MENU_DISPLAYED_ITEMS 5
 Â  Â  Â ;; NOTE: if CS_MENU_DISPLAYED_ITEMS > 5, you have to adapt the DIN settings
 Â  Â  Â ;; in cs_menu_io_tables.inc
Change it to 10. Change this in cs_menu_io_tables.inc
CS_MENU_DIN_TABLE
      ;;            Function name            SR#      Pin#
 Â  Â  Â DIN_ENTRY Â  Â  Â CS_MENU_BUTTON_Dec, Â  Â  Â  1, Â  Â  Â  0 Â  Â  Â ; only valid if rotary encoder not assigned to these pins
 Â  Â  Â DIN_ENTRY Â  Â  Â CS_MENU_BUTTON_Inc, Â  Â  Â  1, Â  Â  Â  1 Â  Â  Â ; (see mios_tables.inc) and CS_MENU_USE_INCDEC_BUTTONS == 1
 Â  Â  Â DIN_ENTRY Â  Â  Â CS_MENU_BUTTON_Exec, Â  Â  Â  1, Â  Â  Â  2
 Â  Â  Â DIN_ENTRY Â  Â  Â CS_MENU_BUTTON_Sel1, Â  Â  Â  1, Â  Â  Â  7
 Â  Â  Â DIN_ENTRY Â  Â  Â CS_MENU_BUTTON_Sel2, Â  Â  Â  1, Â  Â  Â  6
 Â  Â  Â DIN_ENTRY Â  Â  Â CS_MENU_BUTTON_Sel3, Â  Â  Â  1, Â  Â  Â  5
 Â  Â  Â DIN_ENTRY Â  Â  Â CS_MENU_BUTTON_Sel4, Â  Â  Â  1, Â  Â  Â  4
 Â  Â  Â DIN_ENTRY Â  Â  Â CS_MENU_BUTTON_Sel5, Â  Â  Â  1, Â  Â  Â  3
 Â  Â  Â DIN_ENTRY Â  Â  Â CS_MENU_BUTTON_Sel6, Â  Â  Â  0, Â  Â  Â  0 Â  Â  Â ; define this if CS_MENU_DISPLAYED_ITEMS > 5
 Â  Â  Â DIN_ENTRY Â  Â  Â CS_MENU_BUTTON_Sel7, Â  Â  Â  0, Â  Â  Â  0 Â  Â  Â ; define this if CS_MENU_DISPLAYED_ITEMS > 5
 Â  Â  Â DIN_ENTRY Â  Â  Â CS_MENU_BUTTON_Sel8, Â  Â  Â  0, Â  Â  Â  0 Â  Â  Â ; define this if CS_MENU_DISPLAYED_ITEMS > 5
 Â  Â  Â DIN_ENTRY Â  Â  Â CS_MENU_BUTTON_Sel9, Â  Â  Â  0, Â  Â  Â  0 Â  Â  Â ; define this if CS_MENU_DISPLAYED_ITEMS > 5
 Â  Â  Â DIN_ENTRY Â  Â  Â CS_MENU_BUTTON_Sel10, Â  Â  Â  0, Â  Â  Â  0 Â  Â  Â ; define this if CS_MENU_DISPLAYED_ITEMS > 5
Change the last 5 entries to show the shift register and pin number your extra buttons are connected to. Just make sure you don’t have a shift register defined twice. Just change unused ones to 0,  0
Hope this helps
Justin
p.s. I just checked the top one on my sid, and it works for a 2x40 display. I can’t check the buttons though.
Ok, I think I get it. So could assign the last selection buttons to a third Din modules pins like this?:
DIN_ENTRY      CS_MENU_BUTTON_Sel6,       3,       0      ;
DIN_ENTRY      CS_MENU_BUTTON_Sel7,       3,       1      ;
DIN_ENTRY      CS_MENU_BUTTON_Sel8,       3,       2      ;
DIN_ENTRY      CS_MENU_BUTTON_Sel9,       3,       3      ;
DIN_ENTRY      CS_MENU_BUTTON_Sel10,       3,       4    ;
Hope i got this right :slight_smile:
Thanks alot for your quick and helpful response!!
js
Yep, but you don’t have to buy extra DIN modules if you aren’t going to use the inputs. If you only need one encoder and 19 buttons, you can use one DIN module. You just have to reassign all the entries so that you don’t have the same shift register defined twice.
Good Luck
Justin
Ok now I don´t undestand. I thought at it was only possible to connect 8 buttons or 4 encoders to a single Din module? How do toy assign the SR´s to connect more than 8 buttons a DIN module..
Thanks alot for your help
js
js
Your almost there…8 buttons or 4 encoders per shift register, each DIN module has 4 shift registers.
Best!
Smash
ok but still not quite there.. Can you connect 32 buttons to a single DIN module? Doesn´t you need a DINx4 like this: http://www.ucapps.de/mbhp/mbhp_dinx4.gif  to connect 32 buttons?
Thaks for the help and im sorry that im so slow at understanding…
js
Hi JS,
the DIN_X4 is commonly referenced as “the DIN module” because it´s the only version you can get a PCB for. For a DIN_X1..3 you have to use bread board or etch your own PCB. You can connect 8 buttons or 4 encoders to one shift register (chip), so a DIN_X4 is needed for 32 buttons/16 encoders.
Seppoman
ok, thanks alot!! Then I get it,  was beginne to be afraid that I didn´t understand anything at all :slight_smile:
Thanks again!!
js
