12 vdc i not enough for the sid module if you have the 7812 stuffed on it. voltage regulators lose a volt or two, not to mention the rectifier. 12vac would have been fine, or, like is suggested in the optimised psu schematic, 14vdc.
the transformer that he’s using outputs 12VAC not DC. rectified to DC = 17ish Volts. transformers are cheaper to buy than PSUs, i guess that’s why he got one. i think he also wanted the PSU inside the case, so he could just run a mains cable to the box. you’ll get annoyed with having to plug in two wall warts, if that’s what you plan to do.
I also plan to put mine in case,Just the whole unit (the whole wall adaptore) I have installed a different plug.. Thanks for your help..i see Ac DC diference.
So look for 12 ac or 14dc? does the ma matter much what range should I stay between
Again thanks,I have been having troubles,eg.when got kit br1 on core broke(misplaced…duhh)
I am not really a noobie I’ve been circuit benting modding building kits for years (hobbie)
Searching out psu . . . . . . . . this may take a few moments . . .
the circuit will use what current it needs, no more no less, you don’t choose how much current you give a circuit. as i said before, the mA rating on the transformer is only the upper limit above which it will melt. think of it as a speed limit on a road. go above, and you’re busted. ;D
make sure you test the transfomer’s output with the multimeter set to AC, otherwise your readings will be incorrect (on the IC socket pins, though, check with it set to DC). 12VAC going into the sid will be fine just make sure you check the IC socket pins quoted in the walkthrough before you put in the ICs, just in case! ;D
I get higher than 12v off all the psu’s (transformers) when looking at midibox letteres right side up top left pin and bottom right always give me 9.05 volts? right pins? can’t find the link (net limited . .) thanks for all your help, know to test dc on pc (good to know)
you’ll almost always measure over 12V on a 12V trafo/psu, the fact is you need to get a trafo/ psu that is designed to output more than 12 ie get a 14VDC or a 14VAC one. it’s folly getting a 12V one and thinking that because it’s measuring 14V on the output, it’ll work. they’re manufactured to certain tolerances that allow for degradation in the voltage over time (which happens inevitably) so they build them with slightly too much voltage output to give a reasonable working life.
This was an interresting thread, I finished my MB SID yesterday (photos will be posted soon..) and I did only get 11v instead of 12v for the SID supply (apart from the 5v).
I decided to try it anyway and everything is working fine, except for a very annoying 50hz hum which maybe has something to do with either the low SID supply voltage or the fact that the 64 PSU I’m using is not grounded properly. Anyway, I’ll try another C64 PSU tonight.
