SID LCD particulars
Okay,
So here’s the whole story. I’m making a MB SIDv2. I previously had a 2x20 LCD screen and everything was working fine (in 8-bit mode according to my wiring)
Then an accident happened and the damn thing was smashed.
So I bought a new 2x24 screen but in debuging the setup (mostly a backlight issue) I found the 4-bit wiring diagram for V2. I did not include those 4 connections on my LCD so it would be 4-bit. But now the LCD works but is no longer displaying the SID screen. It actually displays text saying it’s a “LCD Screen”
What kind of message is this? Why was my original LCD working on 8 bit?
What PCB? Wilba’s?
The 8bit driver on a v2 is not standard, and if you plugged in a 4 bit LCD with the 8bit driver, it won’t behave… sounds like the corrupted message that arrived triggered a factory message… I wouldn’t do that again, lord knows what you could be doing to the lcd :wink:
So, either wire it up for 8bit (i would) or change the software to a 4bit driver and re-upload.
I see, so it must be configured for 4bit? So it’s 8 bit automatically?
4685’s are 4 bit automatically, unless you configure them to use the user lcd driver, and wilba included a user lcd driver that does 8bit using spare pins. I got the impression you were using it before
You didn’t answer my question… Now I’ll add to it. Which hex file did you upload?
The standard 6851 hex file. I don’t have slaves, so I’d like to activate the 8bit I suppose. No, not Wilbas, just a regular one.
It’s a stereo SID setup however. Should I go with 4bit or 8bit? And what must I configure to get these options?
Well if you can make the LCD work in 4bit mode, I’d say do that, simply because it’s the default and easier :slight_smile: You just need to disconnect the extra four wires from your LCD so it’s wired up like the 4bit PDF you found.
