sid interface with led rings
hi, a am now ready to begin designing my interface for the sid. I have a few questions about some things i want to ad to it:
  1.   Is it possible to add a rotary encoder that controls the overal volume of the sid (threre is an option in the menu to change the volume)
  2.   For live use i want to add a couple of led rings to some of the of the encoders (cutoff, rez and volume), is this possible. I am not using the patch matix, is it possible to use them as led rings?
manny thanx
kriz
  1. yes, you need to add an entry in the encoder table assigned to volume. However, my suggestion would be not to control it digitally (since the resolution is only 4 bit!) but to control the volume from the analog output
  2. will be implemented sooner or later (in 2-3 months when other tasks have been finished)
