as promised many posts ago here are some pics of my quad SID .
The design is obviously based on Thorstens although I prefer the display at the top of the control surface.
Every thing laid out.
Rear view.
Chips installed.
Front panel in progress.
Underside of front panel.
Matrix rear.
Start of wiring loom.
Close up of DOUT.
Ended up removing the powercaps on the cores as they wern’t needed and laid all others flat
to save space as it was becoming a bit of a squeeze.
Note new power supply design as the old one had problems re. heat etc.
Success.
Designed my own soft touch knobs using 3D CAD.
And buttons.
Patterns and moulds for data knob.
D shaft pattern for data knob.
Whole rear view.
Error on envelope section, should read “Depth” instead of “Delay”.
Things left to do?
Lots although the end is in sight,
DIN wiring loom,
some how erase,fill,recolour the error on the envelope section, laser engrave “Depth” instead of “Delay” and fill letters with paint,
stick soft buttons on,
put knobs on,
and have fun… ;D
                                   Jorge…
