I am still trying to figure out how to get the PIC programmed.
Can I simply build the CORE and SID modules, program the PIC with
the main.hex file found in the SID firmware zip, and have a working
SID that is controlled by MIDI fed to the CORE, with no control
surface or display,but be able to add them at a later time?
Yes, but you need a PIC programmer in order to burn the hex into the PIC. You can either build the JDM programmer board shown under the MHBP section, or buy a pre-built (more expensive) pic programmer.
Or you can send the pic and hex file to someone who burns it for you! Lot’s of people will lend a hand if you ask nicely ;D
Yes, I will certainly burn one for you if you need it. I’m in the US. Since the SID runs on MIOS, once you burn the bootstrap loader, you can load new versions via SYX.
I was thinking I would spend the 8.95 and get one(pre-programmed) from smash tv,unless you have a spare 18f you would be willing to get rid of for cheaper.Thanx for the offer!
