I finally got my hands on some working sids for my MB-6582 and have been playing around with it. I gave up on hunting down ebay chips as most of them are not working. I got two already that half work for lead sounds but the rest does not work.
Anyway here is what I have so far:
Sid1 Swinsid x 2
Sid2 8580 x 2
Sid3 Swinsid x 2
Sid4 6581 x 2.
Unfortunately the Swinsids are not as loud as the real chips but they sound ok.
Is it normal that on the 6581 each time you select a different sound that it plays it in very low volume. I cannot hear this on any of the other chips?
What should happen if you select L/R or both chips on one sid? I was expecting to only hear the left or the right or both channels but nothing changes, I always hear both channels without any difference.
I am surely no expert in soldering and I probably did something wrong. If someone could tell me what happens on your midibox if you select the sid channels (L/R), that would really help.
There is no midi connection I am just flicking through the presets of the bank A. The sound stays on until I select another preset and it is especially noticeable on the Zelda Sounds. This only happens on the 6581, not on the Swinsid, neither the 8580. I moved the 6581 around to a different pic and the problem stays with it. Any thoughts?
I tried the three working 6581 chips I have in Sid Socket 1 alone and they all have that issue. If I put the Swinsid or 8580 in that same socket it is gone.
I found this on the ucapps site:
After a sound has been played, you can sometimes still hear it in the background: thats also an known issue with the VCA of the SID chip.
This seems to happen to me but without playing anything just selecting a patch. Is there anything that can be done with settings to get rid of this?
Could you explain a bit more how I would add a noise gate?
I probably should not have mixed two issues into one thread. What is the purpose of the Sid Ch Select (L/R)? I cannot hear any difference, not even on stereo patches.
I wondered about that too but had not invest into answers but this could explain it:
SIDn: toggles between LR, L- and -R. Here you can specify, if OSC, FIL and MOD parameter modifications should affect only the left, the right, or both SID channels. The SID number (SID1, SID2, SID3, SID4) has to be selected with the deticated SID buttons.
A Noise Gate is an Effect which let you choose on which point it should pass the signal.
For example if you use an Microphone and it should just react to your speech than you tweak the treshold to the point it shall react. It’s an standard effect you probably own as a Software Plugin.
got it now. One last question if you do not mind. The feedback pots only work on real chips and not on the swinsids, correct? Or is there a special version of the swinsid that supports this?
Feedback is based on SID Audio In and the SwinSID Ultimate is supporting that. It’s a good point to mention this here so in future I will care about that.
