Sid BassLine seqencer.
It is possible that the sequencer build in MidiBox will be looks like tb303, when we add change step button, notes buttons, pattens buttons, change octave button and bmp encoder? Anyone knows how do that, maybe someone can do that??
I am having a bit of trouble understanding what exactly it is you want, however, the MB-SID has a built-in 303-like sequencer that can be controlled using a number of means, including using the Step A Control Surface (basically the menu knob and some buttons) as well as the Modulation Matrix. I am not sure if you can built a control-surface to model a 303 with it but you might be able to use the MB-SEQ for that, custom firmware, or a mix of both.
Hope that helps!
Tim
Creating and documenting the case and the appr. firmware changes would be a very time consuming task, especially for somebody w/o assembly language skills. :-/
I know that MidiBox has a built seqencer. I mean only to expand a control surface to control the sequencer, for example change notes by the separate buttons like in tb303 no by the arrow.
