SID and SIDPlay
hi all !
finally got my sid+core running  .. but i have one problem, while playing .sid with sidplay:
the tempo is not correct !
most of the songs i tried where 2 times faster than original
… did anyone else experience this ?? any help ?? …
(btw: asid xp is not working with my MIDIMAN midisport 2x2 …?? no midi output)
thx ahead
DROSSEL
As the data to MBSID is sent as a MIDI data - Could this be a problem with the sidplay? Really? Should you ask about it in the sidplay forums?! Maybe there is more “case studies”?
So - Your MBSID is up and running, congratulations!
Bye, Moebius
I also have this problem with my SID. Just got it working by the way :slight_smile:
Does anyone have a solution? Are there any other players which support the ASID protocol?
EDIT: Just found the “ASID XP” on Sidstations homepage. Works great!
