1x DINX4 module (half stuffed is enough if you’re not planning to expand the CS)
1-8 bank stick chips (24LC512)
1x PIC 18F4685 (SmashTV’s already come with MIOS)
other than that 9 tactile switches, 1 encoder + knob, at least 2 midi jacks, 1/4" jacks for outputs (and inputs?), a psu (which one depending on SIDs)
also you could buy some ribbon cable and IDC connectors (have a look at the core module at the store for which ones you need)
you’ll have to do some research anyway, all info is in the mbhp section at www.ucapps.de
also you’ll find a lot of threads here with all kinds of info.
edit: the pic shows the same setup, albeit ghetto style temporary installation in a cardboard box AND the modules aren’t from Smash.
the cables thet go up from the DINX2 and the big ribbon go to the lid where i have a little veroboard with the controls. the cables that go out to the left side are for other purposes.
Very helpful thank you. Where are your boards from? Is there a cheaper European source rather than Smash?
hehe they just look cheaper, cause i did the installation
i got these from Mike’s. just do a search in the forum for smash or mike, there’s lot of info available.
their prices are about the same i’d say. but there are some differences regarding the boards, silkscreen and the choice of connectors.
also they partially stock different things, like for example SmashTV has some modules that Mike doesn’t carry, also the female crimp connectors & crimping tool. mike otoh offers a small 8x bankstick board (in the pic upper left)
but you can find all these info about the suppliers and projects/modules on the www.ucapps.de page, you’ll have to read there anyways.
