[SHARING] my PCBs
Hey people,
as I’m an active member of this community for quite a long time and I really appreciate the help that one gets here, I’d like to share the PCBs with you, that I’ve created over the last two years. I already created a wiki-entry a while ago but I think this might be overlooked and maybe I can give you some inspirations with those PCBs. The layouts are tested but there might be a few mistakes on the silkscreens. If you found out, somethings wrong, please do not hesitate to contact me. Also I didn’t take time to make a clean schematic… so this might look sometimes confusing :wink: But as I said: It’s all tested and should work.
I will not share the PCBs I recreated from TKs schematics, because you can get the PCBs either at SmashTVs shop or the *.brd-layout on ucapps and I don’t want to compete with Tim.
So let’s start. If there is something in the layout that needs to be explained, I will add a little description to them.
In general regarding the SMD-layouts: They can be soldered by hand with a good solder iron. There is no need to have an reflow oven or similar.
1x DIN (SMD):
Description: No mounting holes due to a small size!
[1xDIN.zip](< base_url >/applications/core/interface/file/attachment.php?id=12315)
1x DOUT (SMD):
Description:  The package, that is labled with ULN2803 can be either used for of course an ULN. But the footprint fits also resistor-array (f.e. bourns 4816-series). No mounting holes due to a small size!
[1xDOUT.zip](< base_url >/applications/core/interface/file/attachment.php?id=12316)
8x Encboard (SMD):
Description: This is an pcb that can be directly equipped with ICs and than be attached to the core without any other DIN modules. Distance between encoders: 29mm (fits the DTSM-64 distance layout (see below)).
 [8xEncboard.zip](< base_url >/applications/core/interface/file/attachment.php?id=12321)
Fatar Adapter:
Description: This adapter can be used to connect an 76 or 88 keybed to a DIO-module. You need to solder the jumpers as needed.
 [Fataradapter.zip](< base_url >/applications/core/interface/file/attachment.php?id=12323)
DIO-Breakout:
Description: This adapter is used to split the pins of an DIO-module into more usable pin-headers. See my switch-boards below.
 [DIO-Breakout.zip](< base_url >/applications/core/interface/file/attachment.php?id=12325)
ULN Breakout:
Description: Same as DIO-Breakout.
 [ULN Breakout.zip](< base_url >/applications/core/interface/file/attachment.php?id=12326)
LED Ring (SMD):
Description: This LED ring is made for 0805 LEDs. Good soldering skills needed.
 [LEDRing.zip](< base_url >/applications/core/interface/file/attachment.php?id=12329)
Neutrik-jack PCB:
Description: This PCB can be used to attach easily sustain- or expressionpedals to an AINSER8 module. Solder jumpers as needed and don’t forget the 1k pull up resistor when using it for sustain-pedals / switches.
 [Neutrik.zip](< base_url >/applications/core/interface/file/attachment.php?id=12331)
OLED Breakout:
Description: The module can be directly connected to J15A/J15B of the core. You can then connect OLEDs in conjunction with the display-board directly to the core without soldering any wires.
 [OLED Breakout.zip](< base_url >/applications/core/interface/file/attachment.php?id=12332)
OLED Displayboard:
Description: You need this pcb in conjunction with the OLED Breakout above. This pcb will be soldered directly onto an OLED which you can get for good prices on ebay or aliexpress. Pay attention, that this will only work for OLEDs which have 7 pins single-header connectors.
 [OLED Displayboard.zip](< base_url >/applications/core/interface/file/attachment.php?id=12333)
2x4 DTSM-64 (SMD):
Description: You can connect this PCB directly to the DIO- / ULN-Breakout board (see above), but it should work with classic DIN/DOUT modules too. Switches are DTSM-64.
 [2x4DTSM.zip](< base_url >/applications/core/interface/file/attachment.php?id=12337)
8xDTSM-64 (SMD):
 [8xDTSM64.zip](< base_url >/applications/core/interface/file/attachment.php?id=12339)
8xDTSM-64 distance (SMD):
Description: Distance between the switches: 29mm. You can connect this PCB directly to the DIO- / ULN-Breakout board (see above), but it should work with classic DIN/DOUT modules too. Switches are DTSM-64.
 [8xDTSM_distance.zip](< base_url >/applications/core/interface/file/attachment.php?id=12341)
16xDTSM-64 (SMD):
Description: You can connect this PCB directly to the DIO- / ULN-Breakout board (see above). Won’t work with classic DIN/DOUT modules. Switches are DTSM-64. Distance: 29mm.
 [16xDTSM.zip](< base_url >/applications/core/interface/file/attachment.php?id=12342)
That’s it for now. This list will be updated if there are any news.
That’s Nice! Thank you
Thanks for sharing fantomxr, one question regarding the fatar adapter, what are the BK10-03 and BK10-04 jumpers used for as it’s not written on the pcb ?
For a 88 keys keyboard, do we need to solder bk10-03 + mk10-03 ?
Great job and thanks for sharing! :slight_smile:
Many greets!
Peter
of course not!
you have to check it with the schematic of your keybed. Normally an 88 boards need the mk10-03 and bk10-04 to be soldered.
Thanks for sharing this FantomXR. Do you know if there are there switch caps available for the DTSM-64?
