Seven Segment Displays
It’s probably been brought up already, but it would be cool to have the ability to use one or more numeric value indicators, sort of the way the LED rings are being used now. An ideal setup would be with a user defined “range” for the standard 0-127 value. Like to sweep an EQ knob and see your Hz/kHz value across a few digits or have an X.X dB numeric display for levels (still wondering what those digits on  Francois’ nice-a** console do…).
I had originally wondered about getting the user defined value range happening on the LCD, as it would make more sense than the standard range, but it would be even nicer to have a separate readout closer to where the actual control was.
-George  Â
