It fixed the error with the variables (which is awsome) but it has brought back this issue for me (non-awesome):
I gather flashing the the newer firmware has replaced the bootloader with a newer one. (The change causes display CLCD #3 to #24 not responding). If I reflash the earlier one which worked V1.025 the display problem is still there. I really need to make my midibox HW compatible with the latest booloader.
TK, you kindly did the file diff for me, but there is lot of code to parse to understand what needs to be changed in hardware: Do you happen to remember or have hints for what changed with the way multiple CLCDs need to be wired?
No changes are required for the hardware, but there are software optimizations which might require a better hardware setup, such as buffer ICs for the LCD control signals which are shared between multiple displays.
Major optimizations in universal/app_lcd.c:
APP_LCD_ExtPort_SerDataShift: add more “stretch” operations to slow down the serial clock
APP_LCD_ExtPort_UpdateSRs: strobes J28.WS, you could duplicate APP_LCD_ExtPort_PinSet(2, 0) to stretch the pulse
APP_LCD_Data: uses APP_LCD_PollUnbusy(2500), was APP_LCD_PollUnbusy(10000) before - maybe a timeout happens with this low cycle number?
If software modifications are not successful, please give more details about your hardware setup. This could bring up ideas for improvements.
I’ve made each of the 3 changes you suggested to app_lcd.c separately and together with no difference.
V1.035 (from uCapps) also does not display the RGB matrix with correct colours in half of the array.
V1.036 (which I compiled) also nearly all RGB LEDs are off or incorrectly illuminated.
V1.025 (which I have used a lot lately) displays all 64 RGB LEDs correctly.
Would you like a complete wiring (specification or diagram)? It will take some effort here, but would be good to have anyway. I didn’t do a diagram at the time I built it 3.5years ago (it all seemed so “obvious” at the the time :-).
So I just reflashed Bootloader V1.012 after the flash procedure MIOS Studio displayed LCD #3 to 24 as not responding. I repowered the midibox and the bootloader displayed its test text on all LCDs correctly.
I then flashed NG v1.025 and the midibox is working all correctly again.
So it seems later changes are impacting the RGB LED matrix as well.
Let me know what specific information I can provide to help work through this.
