I WANT set to an encoder, 2 control change
EXAMPLE; turning left CC = 1; turning to the right CC = 2
how you doing?
thank!
how you doing?
thank!
there is no one who understands my problem? :sad: ![]()
I understand the problem, but I can’t provide a solution (yet)
Thak Thorsen!!
I just remember that there is a solution! ![]()
THANK YOU THORSTEN! Then do the tests then tell you how it goes.
Regards, Silviu.
I run this setup default.ngc and everything works great ..(encoder ALPS 24 pp- detent). thanks Thorsten.
ENC n= 4 sr= 9 pins=6:7 type=detented3
EVENT_ENC id=4 hw_id=4 enc_mode=Inc01_Dec7F if_equal=0x01 type=CC cc=96 lcd_pos=1:1:2 label=“Enc INC”
EVENT_ENC id=4 hw_id=4 enc_mode=Inc01_Dec7F if_equal=0x7f type=CC cc=97 lcd_pos=1:1:2 label=“Enc DEC”
Best Regards
