So, I think this is my first post to the list, although I’ve been around here for several months.
First at all congratulations for your idea and your effort stry_one. Kudos also to TK. Great place
As many of us, I’ve been also thinking about a live performance oriented sequencer.
Although I use a set with monomachine+machinedrum UW, which are
great for live performance I’ve have always missed the possibility of having
more tracks available for direct editing. I like also Ableton live, but I’m more hardware
oriented. You can get some idea from this
video: http://monome.org/media/monome40h.mov
I was trying also to reuse as much as possible from the MBSEQ box, but adapting its
user interface to my needs, but your project provides so many good ideas
that I will try to use it. Even provide some help in case you needed.
So here there are some ideas in case they are of some help. Mainly related to the UI.
I was thinking in the following arrangement:
|—LCD—|
K K K … K E B R
b b b b
A s s s s
T X X X X X X X X X X X X X X X X S S S S P M
Ki: Param Pi edit knobs. (e.g. One knob per layer in the MBSEQ)
Ti: Track select pushbutton with LED
Xi: Step ON/OFF pushbutton with LED
Si: Select slot pushbutton LED (at least four, but could be more)
Pi: Play mode select pushbutton
Mi: Mute ON/OFF pushbutton with LED
B: Begin of sequence pushbutton
E: End of sequence pushbutton
R: Random mode pushbutton
A: Select all pusbutton with LED
si: Select column of slots pushbutton with LED
bi: Bank select with LED
General principles:
All the steps in the sequence shall be available for direct editing.
Pushing any button at any row, implicitly selects the track involved
Any edit operation during live performance needs only a pushbutton operation.
A pushbutton operation can be simple (e.g. X on/off) or multiple (e.g <B> + <Xi> simultaneously).
Any pushbutton can have three behaviors.
Short press and release. (e.g. on/off of a step or slot select)
Press, and while pressed modify other UI element. (e.g. Press <Xi> and tweak param knobs for this step)
Long press, performs predefined action. (e.g. Long press <Si> stores current pattern in slot Si)
Ideally pushbuttons with led will be tricolor, so different status can be displayed (e.g. step muted)
Additionally there will be buttons for common operations, like transport (play, stop,…), menu management, tempo, etc.
Up to 16 tracks can be played simultaneously.
The configuration of 16 tracks x n banks x m slots, is stored as a song. Total number of songs depends on memory and n, m.
In the example n and m are four, that seems adequate for live tweaking (16 tracks with 16 patterns each one).
- There is no save action, but I think it is useful that when you are tweaking a pattern and you find some variation that you like, it
can be saved to a slot for later recall. At the beginning all the slots are empty
Some examples:
<Mi>: Mute track
<Mi LONG PRESS>: Clears all the steps
<Mi> + <Xi>: Mute step Xi
<Ti LONG PRESS>: All the steps ON.
<T> + <R>: Initialize Ti pattern with a random steps configuration
<Ti> + <Ki>: Modifies param i for all the steps in the track
<Xi>: On/off step Xi
<Xi> + <Ki>: Modifies param i for the step. LCD shows different param values for this step
<Xi> +…+ <Xj> + <Ki>: Modifies param i of steps i,…j(e.g. you can push several steps for editing. Alternate mode: When some
step is muted, only unmuted steps are affected when edited doing <Ti> + <Ki>.
<B> + <Xi>: Selects Xi as the first step of the track (Changing time signature for this track on the fly)
<E> + <Xi>: Selects Xi as the last step in the track (idem)
<Si>: Select slot Si. Track will start to play Si depending on track play modes (e.g. immediately, beginning of next cycle, …). So for
each track you have a set of variations (4 in the example).
<Si LONG PRESS>: stores current track in slot Si
<si>: Select column of slots for playing. So you can use each slot column as a song section, as in live
left hand row (e.g. INTRO, CHORUS,…)
<P> + <K1>: Selects playing mode for track (forward, backward, ping-pong, random,…)
<bi>: Selects bank bi. (e.g if there are four slots for each track, and four banks, we have 16 slots per track)
I hope that you get the idea with the examples.
For the hardware I was thinking in doing something modular. Well this is true for all the MidiBoxes I’m playing to build.
The idea is to have a common module for basic functionality and a set of specific modules for additional functions.
In this case a set of four track rows that can be incrementally added.
So you start with direct editing of four tracks and you can go 8, 12 or 16 with time. So
it can be accommodated to any budget. I would like also to reuse this module for other Midiboxes
(e.g. Ableton live controller).
Well, I’m doing lot of designs and finishing 3D renderings, in case anyone is interesting in providing
some feedback. I hope to finish some for this week.
Something I’m also thinking from the point of view of UI and overall software to
develop is that at some moment you would need to chose between a
performance oriented sequencer and a programing oriented sequencer. I feel that
maybe too much of the two could make the system somehow confusing.
sorry for this unordered exposition of ideas. I didn’t write nothing formal, just thinking about how I would like live hw sequencing.
