SEQ + LTC problem
hello,
another little problem appeared in my seq project.
the MIDI in and Out ports are working fine. but when i connect the LTC module to the core. my MIDI In port stops working.
The 1st and 2nd midi out s are working fine, the Tx/Rx LED’s from the LTC act  normal…
what could this be?
the oprocouppler ion the LTC is not stuffed.
best,
julian
hehe,
problem solved.
i’ve found a little resistor leg that slipped under the LTC module an caused a little short in the midi line… :^)
julian
fine! :slight_smile:
