seq encoders won't increment, only decrement.
after figuring out why my sequencer reboots itself (heat), i’ve come across a new problem.  the encoders won’t increment any values, only decrement (does nothing when rotated right).  what’s strange is that it worked fine for a while and now it doesn’t.  could the heat issues i was having affect this somehow?  that doesn’t sound like it makes sense to me, but it stopped working right after i put in a bigger power supply.
if i connect only one set of four encoders, i get the same result.  it doesn’t matter which set i connect.
another problem i have from the beginning is that when i start the seq, change some step values and turn some on, then hit play, it goes back to the default sequence of four steps of C-3 being active.  this only happens the first time i hit play and if i change values after that, they stay the same.
i know i wired up some of the buttons wrong but i simply put them to the wrong pins, so that shouldn’t affect anything.  also i have a couple bad encoders which need to be replaced, but i’m waiting on parts.  they’re bad because if i wiggle them to the side, they change values.
any idea what’s causing these problems?
thanks,
drew
Sounds like the encoder pins are swapped, or that the wrong encoder type is selected.
There are some infos about different encoders in the Wiki
Don’t know what could cause the “note delete” issue. Maybe the start button triggers a second function? Have you checked the buttons with MIDIO128? Each button should send a single MIDI event.
