Got my midibox working with LEDs this evening, but after much scouring of the forum and ucapps, i havent been able to solve my issue.
FYI: using WinXP with MB->RS232(serial) module, and programming in Max/MSP
Problems:
whenever i press a button the corresponding LED lights up. granted this could be useful in some applications, but I would like to turn it off, and if i do want to activate it i will do that via software programming.
i have been unable to light the LEDs with noteout messages from Max, however before i turned off the softsynth i was getting chromatic piano notes (so max is sending data) - i think max may not be sending data to the PIC, even though I have selected the driver in preferences.
Other than these issues it’s been working fantasticaly - and all the parts for my 8x16 button and led matrix are on the way - providing an awesome visual method of controlling ableton live…
there are different ways for disabling this “internal feedback”. The easiest is the use of the mk_midio128_syx script, which creates a new configuration. So, just open the default midio128.ini file, search for these lines:
An alternative way is to change this in the firmware, and to build a new .hex file. Changes have to be made in main.asm:
[code]
; Forward Input to Output
; If 0: if an inputs gets an raising or falling edge, the appr. output
; pin will be set to the same new logic level. The output pin
; can be controlled via MIDI also
; If 1: an output pin can only controlled via MIDI #define DEFAULT_FORWARD_IO 1
are you able to control the LEDs by sending Note messages with another tool. E.g., with MIDI-Ox?
Thanks for the tip, and ironically i had just worked it out before i read the message. I’d love to get more into the firmware stuff though, because I’d love to start making some modifications, and eventually create a led/scan matrix which i understand there is no standard code for.
oh well, thanks the hel, and ill get back to it - how i love university holidays
