Sender and if_equal
I’m trying to use an encoder to select the outgoing midi channel by using receiver, sender and if_equal. I’m able to change the channel in a “static” way, regardless of the encoder value, but I’m unsuccessful in trying to use if_equal to control which sender gets activated.
The following setup (with only one sender and router routings disabled) works if I remove the if_equal=Enc:1:1. If it’s in, the receiver does work, but the sender won’t send anything, no matter what the encoder value is. Am I thinking this the right way?
RESET_HW
ENC n=1   sr=1 pins=0:1   type=detented3
ROUTER n= 1   src_port=IN1   src_chn=0   dst_port=OUT1  dst_chn=0
ROUTER n= 2   src_port=IN1   src_chn=0   dst_port=OUT3  dst_chn=0
ROUTER n= 3   src_port=IN1   src_chn=0   dst_port=OUT4  dst_chn=0
ROUTER n= 4   src_port=IN2   src_chn=0   dst_port=OUT3  dst_chn=0
ROUTER n= 5   src_port=IN2   src_chn=0   dst_port=OUT4  dst_chn=0
ROUTER n= 6   src_port=IN3   src_chn=0   dst_port=OUT3  dst_chn=0
ROUTER n= 7   src_port=IN3   src_chn=0   dst_port=OUT4  dst_chn=0
ROUTER n= 8   src_port=IN4   src_chn=0   dst_port=OUT3  dst_chn=0
ROUTER n= 9   src_port=IN4   src_chn=0   dst_port=OUT4  dst_chn=0
ROUTER n=10   src_port=SPI4  src_chn=0   dst_port=OUT1  dst_chn=0
ROUTER n=11   src_port=SPI4  src_chn=0   dst_port=OUT1  dst_chn=0
ROUTER n=12   src_port=SPI4  src_chn=0   dst_port=OUT1  dst_chn=0
ROUTER n=13   src_port=USB1  src_chn=0   dst_port=OUT1  dst_chn=0
ROUTER n=14   src_port=USB1  src_chn=0   dst_port=OUT2  dst_chn=0
ROUTER n=15   src_port=USB1  src_chn=0   dst_port=OUT3  dst_chn=0
ROUTER n=16   src_port=USB1  src_chn=0   dst_port=OUT4  dst_chn=0
select outgoing channel
EVENT_ENC id=1  hw_id=1  value=1  range=1:16  label=“@(1:35:1)Ch: %02d@(1:34:2)^synth”
receive on channel 1 on port 1
EVENT_RECEIVER id=1  fwd_id=SENDER:1  fwd_to_lcd=1  type=NoteOn chn=1  key=any  lcd_pos=1:1:1  label=“Receiver%3i: %e”  ports=0000100000000000
send on channel 6 on ports 3-4
EVENT_SENDER   id=1   if_equal=Enc:1:1  fwd_to_lcd=1  type=NoteOn chn=6  key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
The following setup is the same as above, only for a button instead of an encoder (the encoder setup is commented out). The button if_equal setup works as expected,  the encoder one doesn’t, even though to me they seem the same. The encoder value changes and the label updates on the display, but no receiver is receiving; for some reason the if_equal condition doesn’t trigger like it does for the equivalent (so it seems to me) button value condition.
RESET_HW
MAP1 1 5 6 9 10 12 16
EVENT_BUTTON  id=33 hw_id=33  range=map1  value=1   label=“@(1:35:1)Ch: %02d@(1:34:2)^synth”  button_mode=Toggle
EVENT_ENC     id=1  hw_id=1   range=1:16  value=1   label=“@(1:35:1)Ch: %02d@(1:34:2)^synth”
EVENT_SENDER  id=1   if_equal=Button:33:1  fwd_to_lcd=1  type=NoteOn chn=1   key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
EVENT_SENDER  id=1   if_equal=Button:33:5  fwd_to_lcd=1  type=NoteOn chn=5   key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
EVENT_SENDER  id=1   if_equal=Button:33:6  fwd_to_lcd=1  type=NoteOn chn=6   key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
EVENT_SENDER  id=1   if_equal=Button:33:9  fwd_to_lcd=1  type=NoteOn chn=9   key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
EVENT_SENDER  id=1   if_equal=Button:33:10 fwd_to_lcd=1  type=NoteOn chn=10  key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
EVENT_SENDER  id=1   if_equal=Button:33:12 fwd_to_lcd=1  type=NoteOn chn=12  key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
EVENT_SENDER  id=1   if_equal=Button:33:16 fwd_to_lcd=1  type=NoteOn chn=16  key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
EVENT_SENDER id=1  if_equal=Enc:1:1      fwd_to_lcd=1  type=NoteOn chn=1   key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
EVENT_SENDER id=1  if_equal=Enc:1:5      fwd_to_lcd=1  type=NoteOn chn=5   key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
EVENT_SENDER id=1  if_equal=Enc:1:6      fwd_to_lcd=1  type=NoteOn chn=6   key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
EVENT_SENDER id=1  if_equal=Enc:1:9      fwd_to_lcd=1  type=NoteOn chn=9   key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
EVENT_SENDER id=1  if_equal=Enc:1:10     fwd_to_lcd=1  type=NoteOn chn=10  key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
EVENT_SENDER id=1  if_equal=Enc:1:12     fwd_to_lcd=1  type=NoteOn chn=12  key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
EVENT_SENDER id=1  if_equal=Enc:1:16     fwd_to_lcd=1  type=NoteOn chn=16  key=any   lcd_pos=1:1:2  label=“Sender%3i:   %e”  ports=0000001100000000
Hello
All your sender have same id…
Define hw_id=1 for all event AND id=100..101..102… (or whatever numbering strategy you choose)
Don’t know if it’s the reason of your issue (but it might, same events with different conditional may behave strange and conflict…), you better make a correct config first
Best
Zam
The reason why the sender id’s are the same:
  1. In on _ if_equal _ the id’s are the same for each command. I assume this works because the conditions are mutually exclusive, so that only one of the events will be triggered at any one time.
  2. The same id for all senders works ok with one button, but not with one encoder, which leads me to think it’s not the sender id that’s the problem.
It should work now -> http://www.ucapps.de/mios32/midibox_ng_v1_037_pre13.zip
Reason was, that I “compacted” the storage for conditions so that it fits into a 32bit value. But meanwhile we’ve so many different event types, that I had to spend another bit for the hw_id of the condition.
As a quick solution I sacrificed two bits from the condition value, and gave it to the id
Which means: currently it’s not possible to check for values >12bit anymore, but the ENC event type should be found as expected
Thanks! I will be able to check this next Friday when I’m back home.
Works!
