Send a custom OSC Command
Hi
I could not find anything about this here.
I’m creating my own NGS file and I want to create an Event for a DIN Button.
I want to press the button and the MidiBox should send a custom OSC message like this: “/renoise/select/track i4” to my configured OSC server
But I only read about possibilities like sending midi data and translating them to OSC.
Is it possible to send a “custom message-string” or not, and if “yes” - how?
Greetz schallweller
OSC commands can’t be customized, because there isn’t enough RAM available to store the strings.
The only possibility would be to change the strings of an existing mode in the source code: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fmodules%2Fuip_task_standard%2Fosc_client.c
(you would still have to send MIDI events, which are then mapped to OSC strings by the client)
