Just for more infos, on my side about this issue : on my first laptop (Dell D630, WinXP 32 SP2) I basically have the problems described by Duggle .
-Barely no way to load any “big” NGC file in the file broser like default.ngc (the file opens in the editor once over 20 times) loading stays stuck at 98-99%. With a powered hub, it gets even worst, as it barely loads 6/7% of any file before it says “no response from mios32 core during reading operation”.
-when testing config files (copy/paste of the “getting started” examples from user manual) nothing involving banks works properly : bank is allways 0 in the debug window when pushing the bank select buttons.
-The weirdest, With simple example files like “hello.ngc” : let’s say I’ve got two files “hello1.ngc” and “hello2.ngc” with two different text strings just to differenciate them. I can manage to do :
load hello1
save hello2
and it works as it should. but after that, sometimes, when loading “hello2.ngc” in the editor, I get the surprise that the content of default.ngc has overwritten the original content of the file ! I’ve checked many times: it’s not a mistake on my side…
load hello2
save default
doesn’t work. It says that default.ngc is saved but when loading it, it simply loads the original default file.
More revelant (maybe) : I just changed the “READY” message at startup in the default.ngc for “HELLO”, just for testing purpose. So, when power cycling the NG, it says “HELLO”, and not “READY”. now, imagine me doing the dance of the victory on my couch, because it works ! So, lets go back to the “rotate me!” experiment on the getting started page, click, click, in my hello.ngc config, no problems. So, encoders are basically working, now let’s load the default.ngc file again… Wich says “READY” instead of “HELLO”!!! from what I understand, the NG just acted as if there wasn’t any default file on the SDcard and recreated one new, erasing the previous one with “HELLO” as starting message.
By the way, on my other laptop, (an almost dead Dell D620, with no cpu cooling, very slow, that barely works 15 minutes before it freezes completly, with WinXP 32 SP1) I don’t have any of those issues, file editing, bank creation, loading, saving, everything, so far, from what I can check in less than 15 minutes, works flawlessly… too bad it olny last so little time on a laptop with yoghurt and chocolate all over the screen and keyboard, so many missing keys, and a not working trackpad and buttons : My only midibox compatible computer is my 2 years old daughter’s toy . Damn…
Laurent.
