Hello everybody. I just have one small question though. The SD card module from Mouser is good only me is cost postage and customs too high. I pay but not 30 for customs and shipping if the module costs only 2,30. My question to you in the link below? Can I also use it without problems? Because I always though the schematics of the modules find but no schematics from core 32f4! Is that just as well or I need something else but thanks already times for it. https://www.conrad.de/de/sd-kartensockel-druck-druck-attend-104h-tda0-r01-1-st-1308325.html
Hello Samy
Welcome to the board
The SD card socket you link look like SMD pin at the back side, core 32 have footprint for bottom side TH soldering, it won’t fit. Or maybe if you bend the pin?
Check datasheet/footprint for both.
Best
Zam
Hey thanks for the warm welcome zam .. I’m sorry for the chaos thinking it was not understandable I over the construction STM32F4DISCOVERY CORE sorry zam
This one could work - please try it and give us feedback.
If it doesn’t work, I will send you a replacement for free (at least it’s worth a try, because this looks like a good source for european users)
Alternative solution:
tk first thanks for the mega-project and then also for the mass. Thanks a lot for this. ok sorry I am that I do now only register but with work still family, it is not so easy to cultivate his Hobbys
. So the module because of the big C … Just what I still question is how is the schematics to understand? It’s always different connected to the core. I’ll make you a picture and try to use. Whether I can do it a try so to solder a. core with LCD display running except the SD module is still missing.
looks fine, the leftmost pins (smaller pads) are not used anyhow, therefore it’s ok if they are missing.
not only looks good but also is going well
at least after I have the SD card into the module is pushed no longer display on the LCD, the card is not present. So I think that the core recognizes the card
.. So now but come the next questions … The SD must be formatted in FAT32 or? If so, how can I solve this because I have no card reader on the laptop that’s also on the core or on mios32? .. Secondly yet because I want to obstruct the CS PCB which then so thought that the core of the normal firmware is dubbed and on the SD card then running together of the two WILBA and then alla symbiosis sorry folks I know many questions ![]()
Hey people .. I do not want a new order in the forum open so I write the times in here … Can someone please tell me how I the firmware from WILBA to the SD card already getting the entire network searched think there is not really what a link or something would be nice of you fully. Or a brief explanation
thank you
This page describes how to format a SD Card from MBSEQ (sdcard_format command), and how to upload the right MBSEQ_HW.V4 file:
-> http://www.ucapps.de/midibox_seq_manual_in.html
Thanks T. K oh man for the trees to see the forest for not
okay module is perfect for the people who live in the EU. Thank you for now
