SCS encoder jumps
Hi all,
today I would like to share my experience with encoder on scs, the board version made by ilmenator (semper laudetur), attached to MBHP_CORE_STM32F4, midibox_NG project.
I noticed that sometimes, especially when fast rotating my encoder (I choosed a bourns PEC12R), midibox_NG detects more events than really executed, or worse, events in opposite verse.
Using an oscilloscope I saw many spikes on encoder pin, duration shorter than 1 ms.
Following suggestion on attached datasheet (I hope attaching this document is permitted, I did not find any rule against, but if so I will remove it immediately), second page, bottom right, I modified circuit with some patches.
Now it works perfectly, but I have some requests/suggestion to improve design
  • if anyone knows, please tell me if there is a NGC parameter to allow debouncing on encoder inputs, otherwise
  • for TK, please modify SCS scheme to suggest RC filter usage;
  • for ilmenator, please modify your board design and allow to connect necessary 4 resistances and 2 capacitors.
Thanks to anyone,
Regards,
Cristiano
PEC12R.pdf
Hi!
Yes, there is a debounce_mechanism:
SRIO debounce_cycles=<0..65535>
Anyway: Improving the hardware should be better than software debouncing.
Thank you FantomXR, I missed it!
And now I cannot try, damn!
Ok, I am not pretty sure which of two soultion is better, but… who cares
I’m not sure if software debounce affects encoder events? We’ve heard a lot of stories about low-quality Bourns encoders. Better seem to be ALPS EC12.
I use PEC16 without issues.
You’re right it doesn’t affect it, SW debounce just let some times for the inputs to stabilize, in counterpart we loose reactivity, it’s a balance to find depending on the hardware, and encoder quality of course :wink:
Note: PEC12 and PEC16 are not equivalent(replacement), I also never get any trouble with the PEC16 which is bigger and more solid than the PEC12.
Alright! An interesting article.
https://hifiduino.wordpress.com/2010/10/20/rotaryencoder-hw-sw-no-debounce/
