Hi Folks,
First time here…
I want to thank TK, Wilba and SmashTV for their fantastic work! It is a really addicting project. I also like the idea of slaughtering old C64s ;-).
After getting all the electronic parts, including kits from SmashTV, I am now about to order the frontpanels from FPE for the PacTec PT-10 and would really like to go “glueless” with screws to the 10mm spacers on both sides. Therefore I plan on using the last .fpd (with mount holes) on this page: http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_6582_panels
There, Wilba writes “I strongly recommend anyone who thinks they need this file to contact me for advice and checking their plans, I can save you a costly mistake!”.
I´d like to use flathead black screws with a hexagon socket/allen screw (german: senkkopf).
Questions:
* despite the cost (the last .fpd is the non-optimized version, i think of transferring the holes to the optimized version) is there any pitfall why i should not do this?
* can i have a 1.5mm aluminium frontpanel from fpe with proper holes for flathead screws (in german: reichen 1.5 mm für eine senkkopfbohrung?). The fpe designer says, i should use 2mm for this project, whereas 1.5mm are selectable for the other .fpds. If only 2mm are possible: does this still look good on the PT-10? I am aware, that the tactile components are optimized for 10mm spacers plus 1.5mm panel, but i could shorten them to 9.5mm ;-).
Thank you for your comments and have a good time!
Hawkeye/Peter
