scottsober
Hello to all that can help,
I took apart my mb6582 after it was operating 100% good.I reprogrammed the pic 4685 with studio 2 with id 0,1,2,3 and changed the jumper at core 0 to 0,1,2,3 and used 8580_sid.hex,for
each id in studio 2and got the pics from smash tv.Now the mb6582 does not respond at the control surface.I noticed 4 of the lcd display wires were out,so i reattached them .I guess
the screen says 002 l Pint Ld chn.1
                           1—l Lead Patch
I tried to fix it but could not any help would be great thanks again …----scottsober 6-24-2016
Of course it doesn’t work, you have to use  setup_mb6582 to use an MB6582 control surface.
Thanks alot latigid you solved my midibox problem it fired right up again ! …----kind regards and have a nice day…---- scottsober
I also wanted to know if i need to do anything with the mb6582_asm file or filter files. Which files do in need from the sid 044 download .so far all i used was the
sid_8580.hex and the mb6582_hex are these all that i need or do i need to download more?The presets are in there already.How can I get the demo bassline number
5 to play also? thanks again if you could get my mb up to speed…----scotty 6-25-2016 7:25 am n.y. time
