Hello all, been playing about with the Scan Matrix examples for PIC cores, that’s all working fine.
Is there a way to use the DIn for some other buttons?
TIA
S
TIA
S
I guess that you mean sm_c_example1 with the sm_simple.asm driver, and that you want to use the DIN shift register selected with SM_ROW_DIN only partly for a matrix. Some remaining pins of this SM_ROW_DIN should be used for normal button functions, right?
Yes, this is possible. Since the driver uses “MIOS_DIN_SRGet” instead of “MIOS_DIN_ChangedSet00”, you even don’t need to touch the .asm file
DIN_NotifyToggle() should be called on any pin toggle. So, just filter out the pins which are part of the matrix, all other pins can be used like “normal” inputs.
Thanks, I was using example 2, but switched to example 1 and can report good progress.
Thanks again.
S
