Hello,
i’ve got the following question:
What is the best solution to scale the controller resolution from 0-127 to 0-100?
I think this should be no problem. ??
Greetings,
Stefan
Hello,
Greetings,
Stefan
Hi Stefan,
here an excerpt from the midibox64 application:
;; This function scales a 7bit value depending on a min and max value
;; If the min value is greater than the max value, they will be
;; automatically converted to realise a reversed scaling
;; Input:
;; o 7bit value in WREG
;; o min value in MB64_POT_MIN_VALUE
;; o max value in MB64_POT_MAX_VALUE
;; Output:
;; o scaled value in WREG and MIOS_PARAMETER1
;; USES: MIOS_PARAMETER1 and MIOS_PARAMETER2
MB64_POT_ScaleValue
;; save pot value in MIOS_PARAMETER1
movwf MIOS_PARAMETER1
SET_BSR MB64_BASE
;; send min value if min == max
movf MB64_POT_MIN_VALUE, W, BANKED
IFNEQ MB64_POT_MAX_VALUE, BANKED, rgoto MB64_POT_ScaleValueDo
rgoto MB64_POT_ScaleValue_End
;; set MIOS_PARAMETER2[0] if min > max
bcf MIOS_PARAMETER2, 0
movf MB64_POT_MAX_VALUE, W, BANKED
IFLEQ MB64_POT_MIN_VALUE, BANKED, rgoto MB64_POT_ScaleValue_NoConv
bsf MIOS_PARAMETER2, 0
;; scaled value-1 = ((current value+1) * (max-min+1)) / 128
;; swap max/min if MIOS_PARAMETER2[0] set
;; multiply current value * (max-min+1)
IFSET MIOS_PARAMETER2, 0, rgoto MB64_POT_ScaleValue_Inv
MB64_POT_ScaleValue_NoInv
subwf MB64_POT_MAX_VALUE, W, BANKED
rgoto MB64_POT_ScaleValue_Cont1
subwf MB64_POT_MIN_VALUE, W, BANKED
;; rgoto MB64_POT_ScaleValue_Cont1
addlw 1
mulwf MIOS_PARAMETER1, ACCESS ; multiply with current value
;; divide result by 128 (result >> 7)
;; good trick: just shift the upper bit of the low byte into the high byte
rlf PRODL, W
rlf PRODH, W
andlw 0x7f
;; add min or max value depending on MIOS_PARAMETER2[0]
btfss MIOS_PARAMETER2, 0
addwf MB64_POT_MIN_VALUE, W, BANKED
btfsc MIOS_PARAMETER2, 0
addwf MB64_POT_MAX_VALUE, W, BANKED
;; store result in MIOS_PARAMETER1
movf MIOS_PARAMETER1, W
;; return immediately if inversion bit not set
IFCLR MIOS_PARAMETER2, 0, return
;; else inverse the result
return
[/code]
Note: MB64\_BASE is the base pointer to the page where MB64\_POT\_MIN\_VALUE and MB64\_POT\_MAX\_VALUE are located.
great news! Thank you! ;D I tested it with an encoder. Worked very well.
Next step are motorfaders.
Cheers,
Stefan
Hello again,
i’ve tested it with my motorfaders. If i move a fader it works as expected.
But when i send a controller-message the fader jumps to the non scaled
position (values 0..127). I use the Midibox64e application.
I think, i have to modify “MB64E_FADER_Move” from “mb64e_fader.inc” ?
The values, which are send to the midibox, range from 0..100.
Regards,
Stefan
Hi Stefan,
yes, you have to scale back the value from 0-100 to 0-127
