Ok, I bought a new power supply which is regulated 600 mA 12V tip-positive. I checked the “no load” at 12V on the power supply and it gives me exactly 12V so, as Wilba suggested, it is supposed to be regulated.
I set the JBL shunt on 12V position, then I put a shunt on JR4, no shunts on JPB and the JP shunt in 6581 position. I checked the voltage in orange points and it gave me 10,5V.
Once connected the two boards the LCD came to life as I saw backlight and the “squares” displayed on its upper row, but after 5 minutes the backlight started to blink and in the end it went totally off; I can still see the squares row, so the LCD is working.
As far as I can check I cannot understand where the problem is. Is the LCD backlight definitely dead?
Possibly, but equally possible is a bad solder joint in the brightness pot, the BC337, or a dead BC337.
Note I’ve run my LCD backlight with a similar setup and not killed it, but I don’t set the brightness pot past halfway. Was the brightness pot set to minimum (fully anti-clockwise)? or did you have it at maximum? It might be relevant to what could have gone wrong.
It also could be too much current load, but that seems unlikely with 600mA rating and no SIDs installed.
What kind of power supply is it? If it’s switchmode, they can sometimes do crazy things that I can’t explain.
I recommend testing the backlight pins on the base PCB with a LED. As above:
If you want to test the backlight circuit, you can do this by setting JR4/JBL to “low-power” backlight settings (no JR4, JBL=“5V”) and inserting an LED into the top two pins of J16 header (cathode in pin 16 “B-”, anode in pin 15 “B+”).
Test the voltages of the B+ and B- pins relative to ground and report them here… it will help work out what is wrong.
Try turning the brightness pot, check that the backlight circuit is actually limiting current. If the LED lights and you can change its brightness, the problem is probably with the LCD backlight. If the LED doesn’t light at all, then the LCD backlight is probably OK and there’s something wrong with the current limiting circuit (the BC337), though the LCD backlight could also be dead too. I recently fixed a problem where the LCD backlight, the LCD logic AND the BC337 were dead. Don’t ask me how that happened, but it can.
Do a few tests and get back to me via email… it might be quicker to just assume the LCD is dead and I send you a new one… but you could try to replace the BC337 first.
As I have two 6581 and a 12V regulated power supply I have to set both the two shunts in JPB, right?
JBP, not JPB, but yes. Those shunts are essential to getting the “orange points” (also the SID voltage) exactly 12V. But this is unrelated to your LCD issue… putting shunts in JBP will only increase the voltage to the backlight to 12V, the problem isn’t lack of voltage there (it did work without JBP shunts, it should again).
