Hey yo yo! sickening times with the sammichSID! love it!
I’m working on making a patch to send the various CC info to the different voices/parts and noticed that only the lead engine has the CC messages implemented
Have the other channles/voices been set up yet or is this somethign that needs to be done?
if it needs to be done, where would someone begin to work on the other engines?
some time ago I asked for a reasonable reduced set of parameters which should be directly controlled via CCs, but I haven’t got any response - therefore this feature is still only available for the lead engine as some kind of demonstrator.
However, probably users (including myself) are already happy enough with the 8 knob functions, which can be controlled with CC#1, CC#16..19, Velocity, Aftertouch and Pitchbender.
The big advantage of knob assignments is: a min/max range can be defined - it’s even possible to switch the “polarity”, and to assign two parameters to the same knob.
Means in other words: depending on the patch you could configure knobs so that they lead to the most interesting sound changes within a given value range.
