I have finished to mount sammish sid yesterday evening, check voltage points and continuity and everything is right ! Upload setup into pic and bankstick formating with plenty success ! I’m a happy man ! Last step install the 2 6581 sid and begin to play … but unfortunaly when i power on, no lcd and leds light … nothing ! i try without sid’s, it’s ok i have menu, i check with Wilba 6582, of course i set up the jumpers configuration, and same problem no light on lcd and leds !
I remove control pcb and test voltage, when sid’s are fitted voltage are 7v and 3V instead of 12V and 5V into test points ??? when i remove sids, voltage measures are good !
i have tought about this, my power supply is regulated DC 12 V ! i have read into building manuel that for 6581 use, psu must absolutly match 12 V and not more ?
Yeah, if it is regulated it should deliver 12V DC ± a few %.
The 500mA is a minimum requirement depending on the lcd used. A standard lcd needs about 125mA but there are so called “high current” lcds which need a lot more. So if you got one of those, you have to assure that your PSU can deliver enough current.
<br />Yeah, if it is regulated it should deliver 12V DC ± a few %. <br />The 500mA is a minimum requirement depending on the lcd used. A standard lcd needs about 125mA but there are so called "high current" lcds which need a lot more. So if you got one of those, you have to assure that your PSU can deliver enough current.<br />
<br /><br /><br />
About lcd i don’t know exactly … it was included into wilba kit ! Perhaps i have choosen the bad option about lcd jumpers …
Ok, you’re right guys, psu was in fault. i have changed for another one, measures are 12,45 V into sid pins. I power on, lcd and leds are ok, i start my sequencer, i listen the sammichSID, output volume is correct but after few seconds volume is very very low …
i thought that i have burned my 6581, i remove them and install 6582 checked before into that sammichSID but same thing output volume is very low ???
It sound like my output is not stereo but mono ! some patches doesn’t work at and the others have very low volume … I have checked if i have short between pins of the two 6581 supports but everything is good ! Anyone have an idea where i have to search ? Thanks.
The current rating is also relevant, please tell us that as well.
Are you using a cable with a stereo jack?
With all the sid type switching make sure you don’t accidentally forget to correct the jumpers every time you do it, or you’ll end up feeding a 6582 with 12V…
One thing Hawkeye, i had during 3 second normal volume, only one time the first time i have power on it and now i’ve got always low volume. Even if i power off and start again after i’ve got always low volume output and same thing with 6582 sid’s.
