This is the second sammichSID I am building. I am not able to upload the SID application. I think there is some error whilte uploading, and I am not able to boot up the application when I switch on the power. This is the steps that I mess it up :
1./ Initial testing with MIOS studio, I got correct upload request message in Midi IN window, LCD is “ready” but I am not able to send comand to the LCD
2./ I thought I solder the wrong resistor but I didn’t. I desolder R4A(82k) but end up destroy the soldering pad, I resolder them on the other side of PCB.
3./ I finally found it is a careless stupid mistake, I forgot to put the 6N138 on IC2 socket, that’s why LCD messsage couldn’t be sent before.
4./ Both midi in and out wasn’t working, I think there is something short on R4A (may be), I don’t have a circuit diagram so I don’t know where it links to.
5./ After a bit of clean up, both midi in and out is working under MIOS Studio, I get the right message in MIDI In screen and able to sent text to LCD.
6./ After everything is fix, I’ve tried to upload the firmware “MIOS Hex File Upload”, I think first 10% went ok and then all became error after that.
7./ I saw some code end up error on the screen (some is ok at the beinging), and my sammichSID screen try to reboot MIOS
8./ Mios Reboot text just stay on the Sammich LCD screen forever, obviously the data went corrupted.
What should I do now? Buy a burner to burn a new PIC? Where R4A links to, I am very worry something goes wrong there which make the firmware upload unsucessfull.
Regards,
vintagestars
