Just thought I’d shoot in a comment. I can’t remember it being discussed in this thread. The MeanWell powersupply is: “Fixed switch frequency at 100KHz” - which is well above audible range. But it might be a bad idea to go there if you record or if it is possible that you will ever record it with those high sample rates, 192khz, no? It is IT and Med. equipment approved, but that does not automatically mean that this is suitable for musical applications… Just a heads up if some of u didn’t think of it already.
If building your own is an option - then have a look at this: http://www.murata-ps.com/data/power/oki-78sr.pdf <- switch frequency @ 500khz. I have seen similar ones @ 1 MHz too, but then it get a bit more spendy :P. This one is fairly cheap @ Mouser, but expensive in comparison to linear regulators bought from shanghai @ ebay :D.
I have not much experience in building switchers. It’s a bit more rocket sciency than the most basic linear designs, but not impossible at all if you read some d.sheets, app. notes. of course it helps if u know a thing or two about electronics. <- which can be learnt also :). I have learnt most of what I know from internet studies. But also from some electronics school books I got from a friend and also some from my brother way back - really helps you grow an instinct on how to seperate the good stuff from the bad stuff online. I also had VERY much help from many people @ midibox.org.
So I know that:
…or better yet, are there any for sale?
… you don’t need to go there - at least not in the long run. You probably buy one now (and we have no problems with that hehe), but I guarantee you will enjoy making your own once u get a bit more hang of the elctronics.
EDIT:
don’t know much about MB6582 but if it has a C64 connector I bet it has such a circuit integrated).
It has the DIN c64 power connector indeed. And it also got regulation circuit. BUT read the wikipedia site - it’s all in there - there are several powering options, and not reading this, just assembling it and put the plug in and power it up is not a smart thing to do at all.
The Meanwell RPT60-B PSU doesn’t need any sort of modification to work with MBSID projects
You are partially right here. You are right, it gives you v5 and +/-12V. But SID 8580 and 6582 does NOT accept +12V without a fight. They need +9V. 6581 uses 12V. Also be aware of the powering specs of the -12v rail (depends on what you are using it for, but it might not be big enough).
So basically what you can do is to leave the vregs on the PCBs where the 9v SIDs is gonna live, then feed it with all the 12v you want ;).
It is important to think of PSU as a the whole circuit, not just the external stuff u buy or build -> there might be PSU components on the midibox pcbs also :).
(but the C64 PSU does, that’s why you need to bypass it if it’s already in the MB6582 board).
The C64 brick needs modifications? No, it just needs external regulator circuit to give u everything you need. I understood what you meant ytsestef, but I just wanted to clarify what you were saying.
On MB6582, you have the luxury of setting it up for all kinds of powering options. It is described very well by Wilba in the wiki pages.
Have a nice day / morning ;).
