I ordered the first batch of TPD boards and have some (7) leftovers. 10€ plus shipping each. I’ll be traveling to Germany end of next week from where shipping is extra cheap compared to Norway where I am normally located. BEWARE: smd soldering is required to finish this board.
Also, I have two sets (2 pieces each) of LED matrix modules that I can include for 6€ per set.
that’s all in the Wiki - as long as the modules share the same size and footprint (and I believe that the pinout shown in the Wiki’s datasheet is somewhat “standard”) it will work. I have used modules with common anode pins, but adapting the software for common cathode modules should not be a problem.
I am not sure the modules I used are brand modules. On the backside it says M12088A/BEG and WLG PC5. Those from Watterott share the same data sheet, they might be identical?
For reference (and the shopping cart later on) - which LED matrix modules do you recommend, ilmenator?
Thanks & many greets,
Peter
Peter,
I’m about to try these, they look like common cathode if I read the internal diagram correctly, though. Next week I’ll fetch them and solder them when the board arrives. A supplier in my home country has them for 6,73 € (incl VAT) but I won’t be at home before the following Thursday (ilmenator will be posting the boards later, anyway). I’ll keep you updated, if interested.
Just a little bump to advertise for cheap shipping inside/from Germany. If you contact me by tomorrow Thursday 18:00 Berlin time i can take stuff with me when I travel there on Friday.
Mine is fully populated (save the buttons) but unfortunately I didn’t get to testing yet Anyway, good job, ilmenator!
Yes obviously! Please PM me with your address and tell me how fast you need this - I might be able to send this from Germany end of June. MUCH cheaper shipping…
