[S] MBSEQv4 parts (front panel ×1, Wilba control surface ×2)
Selling MBSEQv4+ parts. The main items are numbers 1, 3 and 4, everything else goes together with one of these (or not — buyer’s choice).
Will ship within the EU, buyer pays for shipping. Shipping varies by destination country, but it will probably be something like 20–30€. Shipping from Finland.
Feel free to ask any questions.
Main items
  1. Front panel 1 (made by julianf). Includes hex spacers and nuts (item 6), no washers. Note that the underside of the front panel has four spots for hex spacers (see image) that used to be glued (“JB welded”) on, but that didn’t last. These spacers are still fastened to control surface 1 (item 3), since they don’t hurt, and give some support against pushing down. All in all there’s 11 hex spacers on the front panel for attaching the control surface.
    Note that the LCD’s have their own hex spacers, lower than the ones above. LCD can be fastened with a maximum of four spacers each, but I’ve used only two per LCD (opposing corners), so there’s only four (and not eight) hex spacers on the front panel for the LCD fastening. — 100€
  2. Wilba control surface 1. Fully working. I’ve also attached a picture of it with power on. Includes item 7 (datawheel + 16 encoder caps) — 110€
  3. Wilba control surface 2. Fully working. I’ve also attached a picture of it with power on.Identical to CS number 1 (item 3), except the colours of the LEDs for GP buttons 1–16 are reversed (red-green instead of green-red). You can reverse this in the MBSEQ’s settings though, if you like them green-red. 100€
Add-ons
  1. Front panel 2. DIY CNC cut, in two parts (CNC working area too small for one piece!). Material: one-sided PCB. Fits the Wilba control surface. No screws, hex spacers, nuts or washers — just the two halves of the front panel. If you buy a control surface (item 3 or 4) and don’t buy item 1, I can include this for free if you like.
  2. DIY CNC cut oaken end cheeks. If you buy the front panel (item 1), I can include these for free. See image for how it looks with the front panel.
  3. 11 M3 nuts. Included if you buy the front panel (item 1)
  4. Data wheel + 16 encoder caps. Included if you buy control surface 1 (item 3)
  5. DIY CNC cut plywood end cheeks. If you buy control surface 2 (item 4), I can include these for free.
  6. 17 encoder caps (salvaged from a broken mixer). Included if you buy control surface 2 (item 4).
I notice I have a mix-up with the sale item numbers (in the images) and the automatic list item numbers. The typed-in references to sale items are correct and refer to the intended numbers in the images; the automatic list numbers are wrong. Better to think of them as bullet points rather than an ordered list. I cannot seem to be able to edit the original message anymore, so this note will have to do.
