I was looking for a serial to midi interface, and I built one based on the midimerger using pic16f877-20 and a MAX232 chip. The unit itself is working, I also downloaded the Yamaha driver. But how to get the interface working via the serial port (using com port 2). Thanks
so far I remember, after the installation of the yamaha driver, there should be a new icon in the system setup directory (where you also setup the display, the soundcard, the network, etc…) - click on this icon, and you should be able to select the COM port.
Regardless of the selected COM port, MIOS Studio and MIDI-Ox should already list a new MIDI interface, do you see it?
Since the Yamaha driver is only Win 3.1 compatible, could not get it to work on winxp. I used another serial driver meant for win98/Xp and it works. The midi merger-RS232 combination makes a good serial to midi interface. The unit that I built can be used as a midi merger as well as a serial midi interface. Thanks again
