does anyone know where I can get tactile switches similar to the ones on my LC clone? (see pics 3/4 way down on page www.ucapps.de/midibox_gallery.html I am called Steve C there!)
I’ve also got some of those type of switch, my idea was to use clear rubber feet as a cup substitute - which bein clear allows the associated button led to shine thru - saves panel holes too!
interesting idea… I dunno if it is easier than drilling extra holes tho… The Led’s would have to be quite close to transfer the coloured light efficiently.
were you inspired by Axel’s first two LC’s? I wonder what the feel would be like. Where did you get the feet from?
I have some of those clear silicon feet which look similar to the buttons of your tactile switches. They’re from “3M”. I’ll get em from our local warehouse. If you can’t find some, I can buy and send some to you. They’re just a few bucks.
How good are they sticking? Do you use additional glue?
Well, i think they are cool as is - they are bowl shaped (upside down bowl;p) so I thought if the panel hole was slightly smaller then the base of it - theyd sit flush without fear of popping out…
Tru say, u can angle the LED tho - besides, I think with some ultrabright jobs the diffusion shud work quite well ;p
Inspired by axels’ ye I got the feet from Hammond: Part# 1421T5CL
I also found some feet like this at a ‘junk shop’ near my house… cheap too!
Though I think that (if) I rebuilt my MBLC (16 faders this time! ;)) I would probably just use the same tactile switches as before. Maybe I would fill the centre hole with glue or something…
