Roland PG200 possible?
Hi all,
Forgive me if this is an obvious question, but would it be possible to create a homemade equivalent to the roland PG200 using the ideas & concepts behind the midibox?
Many thanks
Gareth Darby
Hi all,
Many thanks
Gareth Darby
And why not?! :wink:
The biggest problem is that you need to know protocol specification of the PG-200.. I haven’t seen any information on that.. Of course It could be reverse engineered, but then you would need a working unit, a logic analyzer and patience to extract and analyze data streams..
After that it would be pretty easy to adapt something like MB64 to simulate PG-200..
Bye, Moebius
p.s. It’s a secret (as long as I’m searching for cheap MKS-30 ;D), but JX-3P/MKS-30 Rock! Which one do you have?!
Bye, Moebius
Moebius
I have an alpha junp 2 which I am told the pg200 will work with.  I did consider a jx-3p a while ago but for some reason never got round to purchasing one.
I was under the impression that the PG200 would be a midi controller which just gave users a realtime control surface to their roland synths.  Would the protocol spec just be the CC’s for the relevant parts of the synth?
Gareth
Moebius
Gareth
Oh,
That’s PG-300, and yes it’s a midi device.
It doesn’t send CC’s but SysEx to control parameters, you can find manual for it (and MKS-50, rack version of alphajuno) from:
http://www1.ftg.co.uk/studio/mks/index.cfm?mks=50
And just the SysEx implementation:
http://machines.hyperreal.org/manufacturers/Roland/Juno/info/Alpha-Juno.sysex.txt
I think that using meta events, pots and buttons can be used to send out SysEx, but I really don’t know how it’s done. Check out source files, as I think Thorsten has used it to control some Yamaha AN1x parameters.
Bye, Moebius
Oh,
Bye, Moebius
Off topic, but somewhat relevant:
http://xmidi.com/juno.html
Have not touched my PG-300 in months…
The PG200 has a funny connector that it links to the jx3p/MKS30 with. I’ve also heard that it isn’t possible to use the PG200 at the same time as midi, though I’m not sure how true that is.
 Does anyone know if it is possible to make your own ROM chips to get the velocity upgrade? Actually, maybe it is possible to get them direct from roland…
I’ve been thinking of buying a jx3p…
Of course if you had the contents of the rom you should be able to burn one. Where to get the contents? I don’t really know, perhaps there is a way to read the contents from one rom to be burnt to new one’s? Or maybe Roland has , and will give away, that data.
I have been wondering the same thing as i need roms for a korg dw8000…
Hi, Steven_C
As far as I remember, It isn’t possible to use MIDI/PG-200 same time with JX-3P, but with MKS-30 it is… Sad isn’t it :slight_smile:
I sold my JX-3P years ago.. when I wanted to get rid of excess keyboards on my setup. It’s good for some 2 DCO basses, strings and strange osc sync klangs.
It’s a piece of cake to PROM new firmware to EPROMS, but where to get dump of firmware?!
Anyway.. Steven and Arumblack, check www.analog.no.. could be useful..
Bye, Moebius
Hi, Steven_C
Bye, Moebius
It should be possible - I’ve configured my MB64 to emulate an MPG80, the programmer for the MKS80, which is basically the same thing with different SysEx. Just edit mb64_meta.inc and replace the AN1x SysEx, then set the MB up to call the right meta events.
Here’s my modified mb64_meta.inc.
Also, AFAIK this is true for all the Roland programmers - they send SysEx over standard MIDI, the only thing special about them is the weird cable.
