I’m searching: I’m looking to restore a Juno 106 (MKS7 - the rackmount version), rather than a general purpose filter for MB projects. Though if that becomes an option, sweet.
We’ve been discussing in Chat the possibility of reverse engineering an 80017a clone and open sourcing the design. That would give hackers the option of restoring their dead Junos at a lower price (and more labour) than the available substitutes.
I just found this most interesting image in an article on Matrixsynth.
As you can see, there are separate I/O pins for the VCF and VCA stages, for both signal and control. The VCF is a Roland IC?* called an IR3109 and the VCA is BA662*
So in essence they’re two completely separate blocks, which breaks the cloning problem down into two parts: cloning the IR3109 and the BA662. Or alternatively: making a socketed adapter board that can take SSM ICs for VCF and VCA.
There are trimpots on the mainboard which allow you to fine tune the sound so each voice matches.
I also found a block diagram for the insides of the chip here
_*_according to this they are surface mount versions called A1QH800170 and uPC1252H2 BA662
Other links and snippets:
A good 80017a replacement walkthrough
Guitar Synth Repair Tips has pdf links for calibration, schematics inc 106, MKS30
To check which voice IC is bad, do this:
This guy cut open an 80017a and had a look
Analog Workshop:
my drawing of the Roland SH-101 VCF.
This circuit uses the Roland IR3109 IC …The VCF could also be easily made with two LM13700 or NJM13600 IC’s instead.
*From Harmony Central forums:
Isn’t the JP8 filter a Roland IR3109, making it an IC not discrete?
it’s not a single IC. it’s a name for the whole circuit. / they used several transconductance amplifiers (BA662) or OTAs, custom made for Roland for both LPF and HPF…
about JP6/MKS80 - it does again say it uses IR3109 - but it sounds soo different. they were using, not only different series OTAs, but also they used a 4 x 6dB configuration to get 24dB/Octave - resulting in less warm and drier reonance etc..
