resistor question
So, due to the peculiarities of the guitar synth resistive fretboard shenanigans, I am looking at a design where the output voltage from the fretboard would be between 2.5 and 5 volts.
Is there a way to fix this in the code? I would want 2.5V to send a 0 CC value, and 5V to send a 127(max) CC value. Linear scaling in between.
I did look at the example at the bottom of this page:
http://www.ucapps.de/mios_c.html
but it seemed that that would only change the max and min midi values. I want to change the max and min AIN input values.
Does this make sense?
D’oh!
Should have searched better first:
http://www.midibox.org/forum/index.php?topic=4386.msg28609#msg28609
Although I have 2.5-5V, not 0-2.5V. I don’t think I can change it either. hmmmm…
what about something like
if (pin_value >= 64) then {
pin_value = (((pin_value-64) /63) * 127)
or uhmmm
pin_value = (((pin_value-64) *2 )
Or something
You can optimise this a LOT if needed. I haven’t applied much thought to this so uhm… it probably doesn’t make sense :wink:
not sure what you mean by “the code”, so I expect you code your own app in C:
if you have exactly 2.5 to 5 Vs that’s quite easy:
Get the value as 10bit…
0-5 V = 0..1023
2.5-5 V = 512..1023
…and you just have to bitshift the signal (divide by 4) to get a range between 0..127 =>
[tt](v - 512) >> 2[/tt]
no need for complex divisions or multiplications…
best,
Michael
Heh I knew you’d have the answer on this AC, I was thinking as I typed “I’m totally rushing this and I’m sure AC will come along in 5 minutes with the right answer anyway, maybe I should hit CTRL+F4” :wink:
Definitely not. My post was more intended to demonstrate the concept, I wasn’t sure if squeal is familiar with bitshifting and it’s advantages? Anyway it could be:
pin_value = ((pin_value-64) <<1 )
The compiler will optimise *2 to <<1 anyway, but it’s better to specify it. Problem is, because we are scaling up from 63 to 127,we are generating 7bit from 6bit, so there’s a loss of resolution.
Get the value as 10bit…and you just have to bitshift the signal (divide by 4)
pin_value = ((pin_value-512) >>2)
Much better that way!
Hey thanks!
I had some idea about this, but wasn’t quite sure how best to do it. That solution looks pretty solid.
