RESISTIVE RUBBER RIBBON >>> AIN
Hi there!
I got my hands on a broken CASIO DG20 I’m currently “MIDIBOXING”
The rubber fretboard conducts electricity and resistance varies proportionaly to distance between 2 probes!!
So it looks like I’ve got a Ribbon controller here!!
Here is the problem so far:
I’m using the AIN_VALUE_7BIT function to define a lader for the notes but in 7bit, the resolution is too small, thus causing fret to play neighboor notes randomly.
Is there a method to convert the AIN reading into a 0–>255 resolution rather than 0–>127 or possibly even higher?
I could monitor the readings on an lcd and therefore have a more precise design!
Thanks for any help as I’m still beginning PIC MATHS!
Alex
If you use the MIOS_AIN_PinGet function you will get the full resolution of the ADC (10Bit).
Raphael
Hi Raphael,
thanks for the hint!
Could you tell me which function to use to display the entire 10bit number on lcd for further comparing/handling?
thanks
Alkex
I would try MIOS_LCD_PrintBCD4 (but I never used it myself).
thanks but I dont really know how to work with numbers higher than 255…
I’ll try to experiment differant ways…
all the best!
Try the C wrapper, the programming effort will be much lower
Hi thorsten,
I was thinking about that for some time, but never had the courage to “make the leap”  ::slight_smile:
I’ll give it a shot!
Best regards
Alex
