Reprap, open source goodness.
Just wondering if anybody has seen this before http://reprap.org/. It;s an open source version of a Fabber which is basically a 3D printer, printing precision objects made out of a 3d polymer (or anything that melts under heat and sets again) from a CAD file. Bit expensive to build though, but would definitely consider it one day. It would be useful alongside a homebrew 3D scanner which i’ve seen documented all over the place. I suppose it would be possible to scan my face and print it out to 0.1mm precsion using cheese, could even rig it up to a fax or something to fax objects across the world. it looks like an interesting project and could be a lot of fun.
        G
was your point?
MIDIBOX point that is…
was your point?
There doesn´t need to be one - this is the Miscellaneous forum :slight_smile:
S
S
agreed, was glad to see this link.
plus i want to see goblins face in cheese…
ohh sure…  cheese goblin…  I see your point.
Hot glue face plates?
Rubber Baby Midi Buttons?
knobs, buttons, enclosures… EVERYTHING!  ;D
would mozzarella work ?
replace the polymorph with mozarella et voilà!  ;D
Well… It is a prototyping machine so it’s not like you’d use it for making the actual knob you’d put on the synth… Idea is, you design the knob, then print it, and use the printed knob to make a mould for making the real knobs.
I’ve been on the reprap RSS feed for a year or so now, it’s really interesting to watch these guys go for it :slight_smile:
S
The topic title is “Post here Off-Topic articles”.
I thought that a few people would be interested because it is another open source project, and lets face it, everybody loves robots!
I think mozzarella would go a bit too soft when heated up and not forma a proper layer (unless some sort of cooling was implemented), maybe some chedder or edam would be better  ;D
          G
