Replacement wall-wart for dj mixer
I’m hoping you guys can help me. I’m trying to find a wallwart for my Vestax 05 pro. This is the unit I need http://www.musician.com/document?cpd=GXS31&doc_id=100015&g=home&base_pid=800954&index=0
I can get it for about 26 bucks. I think I can get a non-Vestax brand one for much less. Looking at the specs on the plug, could you guys offer a suggestion? What sites should I look on? Thanks.
any electronics store will be have a suitable wall wart
any wallwart with an inut voltage of 120v and an output of  15V 500ma will do
just make sure the pin config for plus and minus are the same, or if they aren’t solder the original plug to the new WW’s output cable.
“just make sure the pin config for plus and minus are the same, or if they aren’t solder the original plug to the new WW’s output cable.”
Thank you.  Just so I’m clear, that little crop circle looking drawing on the label (beneath the Output details) explains the size of the portion that connects to the mixer? If this is the case I’m glad I posted as I just learned something I had no idea about!
lol! that’s such a great description!
yeah, that tells you which pin is positive and which is negative. In the case of the pic you posted:
the center pin is - and the “ring” is +
