Hi Midiboxers
I am building a SEQ v3 and I would like to remove the metallic shield of LCD Displays to make them thinner.
It seems it can be made easily.
Is there any failure to do it ? What is it supposed to do ?? (Except protecting device).
Thanx
Hi Midiboxers
Thanx
DON’T DO IT!
It holds together the whole thing. The display itself is just sitting on the contacts with no attachment whatsoever. If you remove the case the entire thing will come apart.
too late … no I am kidding ;D
I were sure that this awful piece of metal was not there for nothing. I solved my problem by redesigning the panel.
thanks for your reply nils
No problem. I tried it once with an LCD I ripped out of a fax machine (it was broken beforehand, had a crack in the glass ;-)) I did manage to put it back together using some sticky tape, but even the slightest jiggle and the display will quit working… The DOG-LCDs (you can find them at conrad.de) are really tiny though. Only problem so far, they only come in 16x2…
…and there’s no mios driver for them…yet…
Whoops, yeah, I forgot about that =)
