Register by name
I keep getting the following warning after compiling.
Warning; need to allocate new register by name.
I have had this warning in the past and have ignored it.  Can anyone help?
Regards Robin
There is a sequel to this warning.  In the past I ignored Compiler Warnings.  In this case the for loop fails to work for some reason. The code looks OK.
Robin
Can you paste the code where you think is causing the error?
Can you paste the output including the error after running make.bat?
As before, the warning has now disappeared.  The name the warning was referring to was a function.
I cannot now send you the full message.  I tried the sdcc website but could not find anything.
Thanks Robin
It has happened again. This time I know the circumstances.
I am trying to minimise my code by introducing a for loop. (see below).  As soon as I compiled I received the following warning.
Robin
Microsoft Windows XP [Version 5.1.2600]
© Copyright 1985-2001 Microsoft Corp.
C:\C_Stops>make
Makefile generated.
Makefile.bat generated.
Assembling MIOS SDCC wrapper
Compiling main.c
Processor: 18F452
pic16_allocRegByName:963 symbol name _ReadStoredValues_d_1_1    regop= 00D471E8
gen.c:1890: WARNING: need to allocate new register by name -> _ReadStoredValues_
d_1_1
Compiling pic18f452.c
Processor: 18F452
Linking project
Converting to project.syx
Block 003000-0033FF allocated - Checksum: 2D
Block 003400-0037FF allocated - Checksum: 26
Block 003800-003BFF allocated - Checksum: 09
Block 003C00-003FFF allocated - Checksum: 7D
Block 004000-0043FF allocated - Checksum: 09
Block 004400-0047FF allocated - Checksum: 34
Block 004800-004BFF allocated - Checksum: 60
SUCCESS!
C:\C_Stops>
void ReadStoredValues( unsigned char pin) //__wparam
unsigned char memorised_stored_pin;
unsigned char d;//to increment EEprom reads
q = ((pin-1)<< 5)  + 10;//determines EEProm address depending on Memory pin number.
for(d<=1; d>=13;d++)
SendDump(MIOS_EEPROM_Read(q + d));
//SendDump(MIOS_EEPROM_Read(q + 1));
MemorisedStopsSetLed (8, 14, 15, MIOS_EEPROM_Read(q + 1));//pedal stops
//SendDump(MIOS_EEPROM_Read(q + 2));
MemorisedStopsSetLed (24, 24, 25, MIOS_EEPROM_Read(q + 2));//tremelo strength
//SendDump(MIOS_EEPROM_Read(q + 3));
Problem solved.  Did anyone spot the error in the for loop?  I didn’t.
It should be for(d=1; d>=13;d++)  the < before the = is the culprit.
I am going to take Warnings more seriously from now on.
Robin
robinfawell
It’s good that you were able to discover the error on your own.
I’ve learned to compiled after just about any change, so I can correct a problem while it’s still fresh in my memory.
I wouldn’t ignore any compiler warnings… even if the code looks to be working fine. Jumping on any warning as soon as you see it will save you a lot of time and grief later on.
